1 - 20 of 201 Posts
I am calling on my fellow VW enthusiasts for some much needed advice and direction. At 430,000 KMs my car is in need of a rebuild. After I bought it, (FOR 50 BUCKS!) it sat for 3 years before I started it, and started with a jump.
It ran rough at first, (I now know it would have been better to put a fuel filter in) and has been fairly reliable, aside from battery drain. I have already corrected some electrical, like the battery to starter, battery to body ground, (this wire had 2 ground points on it originally, I just did one to the frame here) and removed other bad wiring.
I found a blue and white wire in the fuse box completely melted back.
I am guessing it was for the 12v cigarette lighter which is not hooked up.
There are a few other wires melted together there, but just the casings.
I can address the electrical by replacing wire by wire.
The other issues I have had were the long warm up period. After starting, the engine would idle very low, with the red light in the dash indicating battery, and there was 8 to 10 volts available. It seemed to keep going, though, the first couple of minutes without touching the gas pedal.
After pushing the accelerator, often past 2500 RPM, the voltage would go up to 12v, the battery light would turn off, but would drop the idle down to 500-600 if you took your foot off the gas. The idle would slowly improve if it kept running. If you tried to drive cold, there was no power and it would stall.
After 5 minutes, it would be warmed up enough to drive. By the time it was warm, the voltage was mostly steady as it was driven. It would run reliably, although it had bouncy acceleration in mid pedal. It always starts hot, and could drive right away. Not so much after 40 minutes.
When i was shifting and other times, the bar gauge was all over the place, between 1 and 3.5!
Whew!! What does it all mean?
Recently, after driving for a year, I replaced the fuel filter. That day, I kept stalling at every stop sign, but I guessed it was from really low fuel. The fuel was DIRTY!
After, it ran pretty good, better than usual. More power. I put my last 20 in the tank, and noticed the fuel pump got very loud, then quiet, then loud, then quiet. I parked the car, and it died. I can hear the pump priming when I turn the key, as usual, but I turn all the way to start, and the starter motor is trying, but no start. My car has died.
So I am in rebuild mode.
Engine as it sits now, in the Convertible:
A better view of the head; It is stamped 26103373H. (With a 52 above it). JH European head.
Solid lifter, 40 intake 33 exhaust. 8mm valve stems. Made in Germany.
This is the other side of the engine bay, with battery and air flow sensor.
Here is a pic of a mystery plug in the back behind the air sensor box, it has 3 wires leading to a female 5 slot plug. No idea where this plugs in. It has been there like that since I bought the car in 2007.
I have a brand new fuel pump, fuel injectors, seals, fuel distributor rebuild kit, (to ensure proper operation of the fuel distributor plunger).
I bought a brand new Bosch distributor, just showed up! (Old one was worn out, at about 60%)
Here is another view, has hall sender with rectangular 3 plug. Date stamp on this part is 1984, and the bottom of the shaft says 2322. The only other option was to buy a distributor with a knock sensor, and I would have had to get a computer for it and wiring harness.
Brand new Bosch ignition coil, plugs, wires, oil and fuel filter. I will likely buy a new oil pump and did buy a new warm up regulator. What else is a wearing part likely to cause me grief?????? I want a reliable car.
I am also installing a big bore throttle body, and likely stage 1 or 3 intake manifold. Tri-y headers with cat, and aluminized exhaust, new throttle cable. As for the existing TB, this is what sits in the car.
There is a tutorial but it uses a different throttle body in the photos. http://www.vintagewatercooleds.com/tech/Techtips/ATStechnotes/throttlebody/throttlebody.htm
There is another link to a page with more info on what I generally hope to accomplish.
http://www.scirocco.org/tech/mk2/5000tb/5000tb.html#fox
The one I bought has a throttle position sensor apparently, (oops) with 3 wires out the bottom of the unit. It has been pointed out by some experts the Big Bore TB in the pics will only work with an automatic, the Convertible has a manual 5 speed 020.
Here's a photo if anyone know exactly what it is. VW and Audi stamped on it, and DVG Made in W Germany on it.
There is a side panel stamped
BO 236
037
061 K
Date stamp is 1989
Could anyone identify which vacuum ports are these two (#2 and #3) and I guess #1 is the mix screw. There is also another vacuum port on the other side, not visible in this photo, But can clearly be seen here.
The two visible vacuum ports here go right through to the inside wall of the TB, the side towards the intake manifold. Advice greatly appreciated.
Another view:
So I am in the market for a Fox? or Cabriolet? Intake manifold 88-89.
Okay, transmission of power;
I found a heavy duty Sachs clutch kit, it has 20% increased clamping force.
Pressure plate, clutch disc, throwout bearing, push rod, bushing and seal, clutch cable and all new bolts, and the release arm just in case. Elring mainshaft seal; Crankshaft seal is silicone. (I will get a new flywheel if needed).
My front windshield is cracked, and the "chrome trim" is junk. I will clean corrosion and fix it.
It is leaking slightly into the car when it rains. There is a small rusty patch by the driver wiper.
I am cheap, so I will find a used glass in great shape off some old junkpile.
GLUED-IN:
1983-1984 GTI
1984 Rabbit
1983-1984 Pickup
1989-1993 Cabriolet
RUBBER SEAL:
1975-1982 All models (Rabbit, Pickup, Jetta, Rabbit Convertible)
1980-1989 Rabbit Convertible/Cabriolet
Some time in mid-late 1989 was the changeover for the Cabriolet.
2-door and 4-door models are all the same within the groups (i.e. a 1990 Cabriolet windshield will work on a 1984 Rabbit LS 4-door).
The windshield frames are all the same, so conceivably, you can swap between the two. I've gone both ways on this (put a glue-in in a rubber-style seal windshield, and put a rubber-seal into a glue-style). Each conversion has it's caveats, but it can be done. What can NOT be done, is use a glue-in windshield with a rubber seal on it. You have to glue it in place.
While everything is apart and accessible, what else do I address?
Any advice for how to make it a success?
The car itself is in great shape, and the parts were all very cheap, but good German stuff. Clearout sales abound if you are willing to spend the time to find them. For me, the last 6 months a couple of hours a day looking through the back pages of the internet. Oh, the Bentley manual is on the way too.
I just traded work for a 1983 GTI, all the serial numbers of the cis system match, and it has a 1.8 block, with 026103373f head. This engine sits with 248,000 kms, (a lot less than the 430,000 kms on the convertible engine.) I am in the process of rebuilding this GTI engine, it will be going in a hot bath next couple of days. New crankshaft, rods, pistons will be ordered soon, after verifying the block and head are in good shape. Bearings, seals and gaskets will also be new. No problem.
I will likely bore to 81.5 if necessary, and want to rebuild the head. G grind would be awesome! Scientific Rabbit or Autotech? Who to go with? Both heads I have are German. Autotech has Zylinderkopf...Port, no polish! And I do have a spare head...
Special thanks to Ze Germans for making great castings.
Somethings that might need a test would be the control pressure regulator, and idle stabilizer valve. maybe even your 5th injector.
When I got my rabbit both my iddle stabilizer vlave and 5th injector needed some attention, after sitting for a while.
:beer::beer:
PICTURES PLEASE!!! :)
#1 is just the Idle Bypass screw, That is for adjusting idle speed. And that TB looks very much like one off of an auto tranny Passat, thus the TPS on the bottom. I have one on my car with the MS.
I would do a compression test to see where that is at, and if it is good, throw all the new stuff on it and see how it runs after that. If you still want to rebuild it, get new bearings, seals and gaskets and rings, hone the cylinders and have the head refreshed and put on the new rings and the new pump and that should be good. If you want to have a real nice running motor, have the IM shaft balanced along with the bottom-end (including the pp and flywheel) and you'll love it.
Discussion Starter · #4 · (Edited)
I have a 5 speed 020 in the car...
The compression tests for the convertible engine Are 150, 150, 145, 150. (From drivebelt side).
Would you rebuild this engine if that was your reading? (Assuming, of course you love 1.8L engines?)
These readings were done the same day the fuel filter was changed, and the car died, late July, 2010.
The fuel pump fuse was removed for these tests.
In the cylinder reading 145 (#3 piston), there was an issue before. The car had been sitting for a few years before I started it with jumper cables, (October 2009) I did not realize this spark plug was not firing for a couple of months. (I did the first tune up of replacing rotor, cap, plugs, wires, oil filter, oil and refreshing the K&N air filter in Dec. 2009).
I was hoping the parts tune would help, it got me around for a while, but it was obvious there was more to it than just that. It needs to be adjusted at all points, and that is a real skill.
There was also a new radiator and expansion tank installed at that time, it just had a rad with a cap when I got it. It leaked. Now it doesn't!
Discussion Starter · #5 · (Edited)
The rings must be done on the engine as it sits, at least! I know that the oil seal is leaking, because of the blue smoke coming from the exhaust when throttle is applied. Could I get away with just new gaskets and rings? A vehicle with this much mileage would need bearings, would it not?
Where do I get VW vacuum hose? I may as well do it, the car is 26 years old! Should be pretty simple, with a vacuum diagram.
The valve stem seals come in a Head gasket set. And I have gotten away w/o doing bearings on a "refresh" in the past, but I also plasti-gaged the bearings to check the clearances.
The vacuum hose can be had anywhere, it doesn't need to be "VW". And the TPS is not used with CIS. The auto uses the TPS for kick-down only.
Discussion Starter · #7 · (Edited)
Will a MS bolt on to the bottom of this TB (or top?) so I can use it? I was told I only have to use two of the wires coming out the bottom to make it work. Only one of them will not be needed for the CIS, and will be negated. Any other opinions on the matter?
MS is not exactly a bolt-on affair. But it will use all three wires(5vdc, ground and reference). I think for the CIS to work, you would have to transfer the switches over. But I would compare the bore sizes to be sure that there is any benefit.
Discussion Starter · #9 · (Edited)
The amount of air this can push compared to what is on the car is BIG. I looked at mine, and it looked like the one in the picture on the tutorial. http://www.vintagewatercooleds.com/tech/Techtips/ATStechnotes/throttlebody/throttlebody.htm They compare the Scirocco 8v with the big valve, that is the difference.
With a ported intake manifold, stage 1 or stage 3, combined with the large (40 and 33, respectively) valves on either of these heads, it is sure to improve. With headers after that, there is no restriction in the system. I am going to use a high flow cat, because I need to pass emissions tests. A windage tray underneath and oil shield on the top of the head (preventing oil blow-pass) will help with oil issues inherent in this car.
So please lets figure out how to mod it! Maybe out of the bottom of that unit would be a full throttle switch! It came out of an Audi 5000, but it could have come from another car!
If anyone knows how to mod this, let me know.
It has VW and Audi stamped on it, and DVG Made in W Germany on it.
BO 236
037
061 K
Date stamp is 1989!
You are forgetting the biggest restriction on the "system", that is the head itself. A quality port job on it by someone who knows what they are doing will pay more dividends than almost all the others put together.
Read through this a few times, and to be honest, it really is hard to make any kind of meaningful response due to the amount of bouncing around from item to item. I will give my thoughts on what I can pick out without digging too deep, and I guess I’ll wait untill later for any other question to pop up.
> First the throttle body. It will not work in the current condition and there are no mounting holes to install a micro switch (I think that is what MS really refered to). Unless someone has some kind of trick to convert it to being able to mount throttle switches, you will have to get another one. I suggest finding a Cabby manifold and throttlebody being sold as a set on maybe Ebay. One from a newer Digifant engine (2H), the manifold is better flowing then the current one, forget that stage 1 and 2 stuff, and no grinding is needed to mount the larger TB, which if bought together is already mounted.
> Although that ignition distributor is the correct one for the original engine, 1.7L, it is for an automatic. It might not have the very best advance curve for a manual. You can replace the vacuum advance canister with a single port one with no problems. The dual port was nothing but a quick emission thing really and is not needed. If you want something better, look for one used in the early RD or maybe HT engines (I can get a number if you like).
> Which of the vacuum ports you will use depends on what has to be connected. The one facing the rear, not visible in the photo as you named it, is for sure manifold vacuum. I would think one of the front two is manifold vacuum and the other is ported vacuum. In any case, the TB can not really be used as I pointed out and things will change when you have the correct one. If only the vacuum advance will be connected then manifold vacuum is best.
> That second ground should have been kept. VW often uses a ground cable that connects to the frame and the engine/transmission. If you no longer have that cable then get yourself one of those flat braded ground straps and run one(or more) from the engine to the chassis. Due to the rubber mounts it is important to have the engine grounded.
> Think much of your charging issue is that mega power draw for a sound system. That is just a guess on my part it that is what the power take-off on the battery is for. Drawing a lot of power will put a load on the engine and cause it to have a poor idle at times. The dash light and having to race the engine to get it to charge sound like the alternator is going bad, it is not as some would say “normal”.
> Again I assume here, but this bar gauge that bounces around, is it a vacuum gauge? If so it will move around a lot as it is sensing the changes in load on the engine. If it is an oil pressure gauge it will also move a lot, but not as fast or often as one for vacuum. Either one, or both as some like myself use, can help a lot if you learn how to read them and keep an eye on them for signs of trouble.
Discussion Starter · #13 ·
Ok, someone should tell you that the 924 TB won't work because that TPS is a variable 0-5v signal, and the switches are open/closed 0v or 5v.
Thank you! The guy that sold it to me assured me it was the same switches on the top, just a better unit with the switches integrated. There was just no other info at the time to find. Like wandering in the woods without a map. Okay, mystery solved. It doesn't have anywhere to mount switches up top, either. Anyone with an automatic out there need a TB? Hee Hee Or, I could just return it for a couple items he has I know I do need. I wish it worked; it would have cleaned up the look nicely.
Discussion Starter · #14 · (Edited)
"> Although that ignition distributor is the correct one for the original engine, 1.7L, it is for an automatic. It might not have the very best advance curve for a manual. You can replace the vacuum advance canister with a single port one with no problems."
+My distributor on the car is in desperate need of bushings. It is burning rotors badly. When you grab the rotor, it moves A LOT. I know a guy out in the bush that has a shop, and he has a lathe. He said we could just make some bushings. It seemed like a long shot to me. I could not find bushings for this anywhere. He also has machines to flatten heads and blocks. And a distributor tester.
I guess the question is, would I get as much out of a rebuilt as I would out of this new model, even though it is for 1.7L?
Would the advance curve be better suited to my car after switching the vacuum advance out? (25 bucks)
Is the only other difference in the distributor the size of the windows inside the hall sender? Wouldn't I be able to bolt in a 1.8L sender to this unit that has the proper windows? Is it more than just the hall sender inside, is it a gear thing?
The windows should be the same on all 4 window dizzies. And as far as I can tell by looking thru my EKTA, there is no difference in dizzies with respect to what tranny is in the car. They are the same.
Discussion Starter · #16 ·
Ah, but I am doing a head port. I have an extra German head, and am sending it out to Autotech or Scientific Rabbit after verifying it is good. Autotech's solution to porting is Zylinderkopf, which has sport springs and Ti retainers and other great stuff. Combine it with large intake, TB and headers, it will be a great car. Why do any of it if you don't do all of it?
Any single part with restriction will prevent flow. I don't mind paying to have the head done! Even after reading the MASSIVE porting thread in here I don't know enough about it to do a good job!
I would like to build the entire engine of the GTI, (Pics of the GTI engine are coming soon). and continue to use my Convertible until the GTI engine is ready to be installed. That way, I still have my daily driver. (If I can get it to run.)
I don't remember seeing that you were going to have the head ported. And as far as the GTI motor, it should be as easy as a motor swap, with some minor fuel mixture adjustments. I have a 10:1 short block sitting in my garage, but I can't justify the rebuild of it since my current motor only has about 60K on it and is less than 3 yrs old (on its rebuild).FIXED;)
Discussion Starter · #18 · (Edited)
You are indeed lucky, with a motor that young. The great thing about these old cars is they were amazingly well made. Putting in new old stock parts is the closest you get to feeling like they drive new again. And a couple of modifications to improve what we have discovered to be their inherent weakness, we can expect them to perform like they were really meant to. Free up power.
I have always liked this car, since it came out. A lot of cute girls tell me how much they like my car, and some just hop in for a ride. I haven't even fixed it yet!
It IS the people's Porsche, and VW back then made quality, not like the cheap made in China stuff.
I have spent less than 1000 dollars so far, and I could not even buy another used car in a questionable state of repair for that much.
It is worth it to overhaul this car!
The body and undercarriage are solid!
The German made ones were treated with a polymer in all the likely rust areas, and the use of Zinc helps fight rust.
I have owned and driven many cars, new and old, and yes, a Lotus performs better, but the Rabbit is just FUN!
And a brake job doesn't cost thousands of dollars.
Once I have this car running properly, I am going to custom paint, seats, new seals, top and blue furry headliner. A new Optima battery and the biggest alternator I can fit is also the plan.
Speaking of alternators, anyone know how to put a HO Alt on this car? I love loud music.
I especially love the simplicity of mechanical. There is logic. I have had SENSORS on other cars cost me over $1000!
I once had an American made vehicle acting crazy almost claim my life as the on board computer crashed. It subsequently burst into flames as I was driving on the freeway.
Discussion Starter · #19 · (Edited)
:beer::beer:
Hi Brunke! :beer: :beer:
The Warm Up Regulator A.K.A. control pressure regulator. This is a pretty integral piece of the fuel system. Not only does it work as a choke for start up, but also controls the amount of fuel available to the injectors.
I bought a new one. It is still on the way, and I will have pics when it arrives. Then I will have two spares (off the Rabbit convertible and GTI) to attempt a mod to make it adjustable.
The cold start valve on either car is rough. I will have to buy a new one, with gasket.
Idle stabilizer valve. Does this car even have one?
I have seen them in front of the intake manifold on newer cars, but does this car have one?
Some California Rabbits have a digital idle stabilizer.
It is integrated into the breakerless transistorized distributor system.
(Hall sender ignition distributor).
As far as I know, my car uses an idle boost valve.
The auxiliary air valve is behind my intake manifold.
The frequency valve is a part of the airbox/fuel distributor, it regulates the air-fuel ratio at the throttle body. I am having a hard time finding one. (at least the proper part#)
I did find one but at $400 it will have to wait!
Not to worry, I will provide play by play on this build as it happens!
Discussion Starter · #20 · (Edited)
Interesting. I like this idea. No porting required? Better flow? Sign me up! But, are there any other issues to this manifold? How does it interact with CIS? I love CIS! I love mechanical! It is relatively affordable!
There must be some way to change out the bottom plug on my TB and cause it to switch the way I want. There has got to be a way. The throttle valve opens when I push the gas, right? That sends a signal to where? Oh, I need the Bentley....!
Patience, it is on its way...
(The electrical diagram is somewhere, I will put it here soon.) We are in the technology age! It can be done.
It sure does seem easier to just bolt something on, though...
Anyways, on CIS the fuel is regulated by the air flow meter. Where do the signals from the TB go?
1 - 20 of 201 Posts
