The head has been reconditioned, all modifications complete.
Lots of fine sludge must be washed away, including the inner channels.
There was a frost plug on the side by the tensioner bolt, 24mm.
This was removed, and the entire head cleansed, dried. New plug installed with aircraft sealer.
The valvetrain has been installed with the new stem seals, after springs were checked.
Lifters and shims in, only 3 shims needed to be replaced to be within spec.
The insides of this GTI are cherry compared to the high mileage Convertible engine.
There is a good write up on adjusting valve lash here...
http://www.driversfound.com/scirocco/techtips/engine/valveadjustment/
The pistons were all turned to the middle, to ensure valves and pistons do not collide.
Notice on the head the lifters of 1 and 4 are mostly up, valves seated.
Next step was to torque the head bolts down.
This was done in 4 stages, first (in sequence) to one torque setting, then the next.
Then they required one half turn past that, breaker bar, done in (two) one quarter increments.
The next logical step was to tackle the timing.
This proved to be quite a challenge.
The dot on the intermediate sprocket is visible in the crank pulley notch.
Hold that while checking the dimple on cam side of the cam sprocket is level with the top plate.
After tensioning the roller, you can manually turn the crank for a few loops of the belt.
It should line up time and time again if you got it right, if not start again.
WARNING! DO NOT ATTEMPT THIS YOURSELF! I AM NOT RESPONSIBLE FOR YOUR ACTIONS!
That little blue arrow above points to the crankshaft bolt that must be torqued to 148 ft/lbs!
So how do you torque down a bolt to something that spins?
The thick nylon strap broke as it tensioned the crankshaft sprocket for torquing.
What now? You could get a steel bar and drill 5 holes in it then bolt it on with throwout bolts.
Or, you could get some nylon rope, feed it down the spark plug hole so it lines the cylinder walls, make triple sure no other valves will possibly hit a piston, and torque away.
Leave enough hanging out so you do not lose it inside.
After a pause,
the oil controller goes in, the injector cups installed with Locktite.
Now the fun stuff. Intake manifold and header time. New studs and locking copper nuts.
Stainless steel for the intake manifold.
There needed to be a solution for header to block support, and the solution is tacked in place.
The two bolts to the block were in the same condition, originally. The left one was cleaned.
Those were originally the bolts for the front motor mount of the GTI!
This was a very good solution, very strong. One of the block bolt holes needed to be tapped.
It was welded up and trimmed, awaiting a sandblast, prime and paint. Knorrigend!
This front motor mount was an extremely tight fit, even with the super grease supplied.
It ended up needing to be pressed in, not easy with no good surface to push on.
After a pause,
