Re: 8V FAQ (Coupe__88)
I know that all of you know this, but...
Cut out the bottom, headlight side, and fender side of your airbox, with a K&N drop in... maybe 5 hp at the top... maybe.
Replace your throttle body with an audi 5000, or A2 golf jetta CIS car. larger butterflys, more air...
Get a cam from a digi 2 GTI, it has more lift and duration than yours, a little stock upgrade, especially if your poor...
Replace your airtube with painted PVC pipe (the white stuff) in a 3" diameter. I know it sound ghetto, but would you rather spend $10, or $90 from ABD???
All the A1 CIS cars, get an A2 cis fuel distributer, the air side is larger for better flow.
Scirocco owners... buy the Autotech, or make your own Alternator wire upgrade. it really helps, especially with a system and better lighting. i never had a dead battery with this upgrade.
Speaking of alt. upgrades, most if not all 8v owners can upgrade to the 120 amp audi alternator, but i don't know how... someone help please.
Oh yea one more thing... i learned this the hard way... ANY TIME YOU BUY A CAR... RIP THE OILPAN OFF AND CHECK THE OIL SUMP TUBE!!!!!!! i roasted my german spec rocco this way... just buy a gasket, and change the oil, but clean out the tube to be on the safe side...
