1 - 20 of 34 Posts
ok guys, i'm new, but i've been reading posts here for a while already and always found my questions so i didnt need to register.
but couldnt find this so i'm asking now.
i purchased a fbmfsw from 8v and i'm trying to retrofit on my 8p3.
today trying to assemble, realized the harness connector from the airbag was not fitting...
is there a way to make it work?
do you know if its worth to try to repin the connector from the harness, or if there is a way to replace the G85.
please tell me someone knows about this, or has already done this mod.
thanks in advance
2016 edit!! the correct way to get it working, full guide
Ok, here is an edit with everything learned in this thread thanks by the contribution of everyone from several forums.
In order to achive the knowledge to do this, several parts had to be bought and learn from mistakes.
this is how the original steering wheel looked like
and this is how it looks with the upgrade
here working 100% functional, error free
First of all, you must know if your steering module and slip ring is multifunction compatible.
a 'HIGHLINE' steering wheel module and slip ring are needed, check if you already have these with VCDS>16 steering wheel
from 2006-2008- module 8P0 953 549 F
from 2009-2012- module 8p0 953 549 K
slipring- 1K0 959 653 D
Then, the installation process is exactly the same as switching any other steering wheel for our car, there’s a bunch of threads of that in the forum, BUT in this case the idea was to use the FBSW from the 8V that was something not done before since it was from a newer car and it might not work… anyways a bunch of other newer audis come with the ‘same’ steering wheel which has the same looks as all the post 2012 cars (S4, S5, S6, etc)
But there is an issue, there are two of this kind of steering wheels with the same look, 8V and 8K. The difference is in the multifunction buttons, and the type of communications they use with the ECU
-8V steering wheel, comes with LIN2.0 highline buttons, and Single Stage airbag.
-8K steering wheel, comes with LIN1.3 lowline buttons, and Dual Stage airbag.
Our 8P cars come with LIN1.3 steering module, so 8V steering wheel buttons WONT WORK.
So in that case it’s just easier and recommended to buy the 8K steering wheel since its plug and play.
Moving further to the airbag part, some 8P come with single stage (as I’ve read its from the older ones, until 2007 or something like that) and some are dual stage (from 2008 and on)
In that case:
-If your car is from 2005-2007, get the 8V airbag (because of single stage)
-If your car is from 2008-2012, get the 8K airbag (because of dual stage)
If you get to buy the 8K airbag, you need to re-pin the wires in order to make all the multifunctions to work. Here is a little diagram of how the original 8P, 8V and 8K wiring is, and how you need to re pin your 8K airbag to make it work (sorry if it is in Spanish, you’ll understand it)
IF YOU MISTAKENLY ALREADY BOUGHT THE 8V STEERING WHEEL
It’s not everything lost!! (I’ve been through it, and fixed it)
You need to buy the lowline buttons from the 8K steering wheel, the code is 4L0951523E, and it can be purchased here: http://www.cars-equipment.com/www/en/shop/audi/oem-4l0951523e-audi-a4a5s5q7-steering-wheel/ , you can chose either DSG option for paddle shift compatible or without them.
ONCE YOU DO THIS, it will be the same as having the 8K steering wheel, and everything should be working fine.
ONE IMPORTANT THING. DON’T TRY TO USE A SINGLE STAGE AIRBAG INTO A DUAL STAGE, AND VICEVERSA!! If you bought the wrong airbag, I recommend you to sell it, and for the same price, get the right one.
thanks in advance
I don't know about the 8V steering wheel, but I did a full MFSW retrofit onto my car. I had to buy a separate wiring harness in addition to the steering wheel. Here's the link to the thread:
http://forums.vwvortex.com/showthread.php?6944895-DIY-Full-MFSW-with-Paddle-Shift-Retrofit
A couple of things: Did the airbag come with the 8V wheel, or is it from your original steering wheel? If it came with the new one, is there an older gen airbag that will fit? If you have pics of what you're talking about, I might be able to help.
thanks npace,
this exactly was my guide and inspiration to upgrade my steeringwheel, but foolish me... i took the wrong steering wheel i think.
i wanted it also for the paddle shifts, and specially these ones from the 8v that were bigger, but didnt know it was not gonna fit :/
currently in my car i have the exact same steeringwheel and airbag as you
http://i1291.photobucket.com/albums/b542/nbpace/2014-03-31_13-21-01_117_zpsb8243efa.jpg
and this is the one i purchased.
http://i214.photobucket.com/albums/cc65/scooterperu/10711753_10154639612275230_1491880971_n.jpg
http://i214.photobucket.com/albums/cc65/scooterperu/10514966_10154639612220230_1597302746_n.jpg
the harness on the new one has just one detonator, compared to the old one that has two, and that is my main problem and worry about re-pinning the cable, because probably it wont work and its a risk.
thats why i'm thinking changing all the clockspring, that probably might work.
all ideas and opinions are welcomed and helpful!
thanks again
I cant contribute anything useful in here.. I just wanted to add that GOD DAMNIT I'm upgrading my wheel next year. The new wheels look and feel so nice :heart:
i knoooooow!! thats why i really want to fit this in the car, somehow! and the fact that i actually have the wheel in my hands makes me wanna have it way more!
thanks npace,
thanks again
So the connector doesn't fit into the clockspring? If that's the case, I think I have more bad news for you. You can't change the clockspring without replacing the steering control module. If you do that, you're getting into a potential issue with the canbus system. I recommend you sell that wheel and get a FBSW from something that's a direct fit. I'm not saying that it's impossible, but it sounds like the cost won't be worth it.
Discussion Starter · #7 ·
****, i was afraid for something like that.
something like this one, and sounds like a pain in the ass...
http://audiforum.us/threads/idiots-guide-to-mfsw-install-everything-you-want-to-know.4672/
this fbsw was so nice :( such a pitty...
Again, I'm not saying it can't be done. I realize that there are a few more functions on the wheel itself, but why not get an 8P S3 steering wheel? Those are known to fit and have pretty much everything you're looking for.
Discussion Starter · #9 ·
yup i get it ;). i bought this one as mistake (more confusion than mistake), and bought it when i was in the States, now i'm back at home in Peru, and its gonna be a pain in the ass to get the 8p s3 mfsw, but i'll find out a way to buy one.
shipping it is not a great idea because they make you pay a crapload of taxes and **** like that.
i'll find a way out on this. i'll keep you guys posted!
Discussion Starter · #10 ·
here's an update of what i've been trying to do.
tried to re-pin the conector, using my old airbag housing for the cable.
it was super difficult to get the cables out, but at the end got it all safe.
found out what was each cable for, and placed each of the new cables on the old housing in the position they were meant to.
So, by then everything was "ok"
i left the airbag for the end so i didnt plug those yet.
now, plug it on the clockspring and connect the vagcom and try to set the coding.
my original coding was 0010012, and according to vagcom, the new steering wheel should be 0012112 (because of adding the mfsw and triptronic), BUT then the error pops up "Code rejected error 31: Request out of range"
so i think the problem is the Control Module, that is not made to work with multifunctions, or is there something i need to modify somewhere,
can someone help me with that?
since now the cable is supposed to be the same as the old one i thought plugging it was gonna work fine, but it doesnt.
here is the scan of my steering wheel:
Tuesday,23,September,2014,14:42:26:37920
VCDS Version: Release 12.12.2 (x64)
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Control Module Part Number: 1K0 953 549 DB HW: 1K0 953 549 DB
Component and/or Version: J0527 037 0070
Software Coding: 0010012
Work Shop Code: WSC 06314 000 00000
VCID: 75EA01A21C5516B6B81-8020
No fault code found.
since unplugging the pins from the housing was so hard and i already had to leave, i decided to keep the wheel placed without any connection other than the horn for some days till i go back to the mechanic. this is how it looks like.
Discussion Starter · #11 ·
anyone?
is my problem the module control? in that case, whats the module control i need,
i've been looking on ross-tech and and there is a HUGE list of modules with different types, softwares, lines, versions, etc.
mine was a 'midline' so as i far as i read, midlines dont allow multifunction.
1k0953549-DB is type 2, sw 0070, midline and doesnt show any 'LIN' version.
do i need to look for another module with the same specs, just 'highline'? i am a little confused and need some help.
if that is the case i mentioned above, i cant find cuz all the type2/sw 0070 that are highline, have LIN version 1.3
what is the regular module number that comes with most of the 2010 8p with MFSW (btw my car is an 8p sportback 2010 1.4tfsi)
HEEEELP
cant help on that one, but that steering wheel looks gorgeous.........
Where in Peru? I am in Iquique, Chile. I was in Tacna for the fiestas patrias weekend ;)
subscribed for updates.
i personally thing the 8V wheel is much nicer than the 8P ones.
If this can be done i'll be all over it!
Discussion Starter · #14 ·
Buenaa!! en Lima, saludos!!
indeed it is!!
Thank you guys!! lets cross the fingers to make this mod able to everyone!
I've done a little research on this, and here is what I think: You need an airbag harness off of a round 8p wheel, because that already has a single detonator. Then you'll probably need to re-wire as above. But..... here's the sticking point: you probably only have 8 inputs on your steering control module: 2 for the detonators, 1 for up-shift, one for downshift, one for radio volume, one for radio channels, one for voice activation, and one for bluetooth. That's all the 8p models came with. You *might* be able to make it work with an 8v control module and clockspring. But..... my inclination is to believe that it will not be recognized by the can-bus. My advice is to either settle for an 8p wheel, or sell your car and buy an 8v. Sorry. Unless you have tons of cash, I really don't see how this conversion is worth the cost. Just my opinion.
Me gusta la caja china ! :beer:
I wanted to see this work .. but too dangerous to mess so much with the airbags connectors and suff. peace
Discussion Starter · #17 ·
ok, in case i buy the right steering wheel. what else do i have to buy? because i still need a control module for multifunction right?
does anyone know what is the right module i need, cuz there are a looooot of variables
Discussion Starter · #18 ·
yesterday i was checking random a3 on instagram, and found this!! someone posted a picture of one 8P with the same steering wheel, so this mod HAS to be possible! :O it gave me some hope on this
Discussion Starter · #20 ·
That 1.4 tfsi comes with manual tranny? Just curious. Well i would like to get the same steering wheel. If not the s3 fbsw
here, i've only seen DSG yet, but as far as i know, theres 6speed manual on the 1.4tfsi
1 - 20 of 34 Posts
