It's a 1990 cabrio digifant II. The battery light used to light up and if you bring the rpm a bit up it would go away. However, now it doesn't light up and i have to rev to about 3500 rpm in order to see the battery charging on the volt gauge. I read that the faulty led light can cause that so i switched led around in the cluster. That wasn't the problem.
Anyone else had similar problem? Any help is appreciated.
Thanks in advance.
Thanks in advance.
