Ive got a 90 Jetta GTX with the 2.0L 16v motor running CIS-E Motronic. Runs really rich and its got a pretty rough idle and giving it gas the throttle has slow response and wavers around inconstently no matter what position I hold it at. Obviously making much less power with all the hesistation. Gets a bit worse with the engine warmed up. Harder to start when warm. Engine diesels after ignition is shut off. First starting it idles around 700 then climbs up slowly to around 950 rpm.
Ive got the haynes and bentley manual for my car and have been checking everything I have the tools for as specified by the book.
Things Ive tried:
Replaced vac lines and checked for air leaks; none found
Replaced/repaired damaged wiring going to sensors in engine bay
Cleaned and tested ISV - works
Adjusted air plate sensor position to spec
Replaced entire distributor unit, car now has basically all new ignition components, from coil to dizzy to plugs and wires. Adjusted timing for ignition as specified by bentley, cyl 1 at tdc, lined up the distributor mark with the center of rotor. Checked other timing marks, all were good.
New cts
Idle switch clicks on off for closed and full throttle properly
New fuel injector seals
Replaced broken ignition reference sensor
Checked fuses
Tested csv
Tested carbon canister solenoid valves
Ive pulled the codes from the computer and gotten these inconsitently.
2231, idle speed stabilizer system exceeded range
2112 ignition reference sensor (before replacing)
1111 defective ecu
1231 speed sender
2342 o2 sensor system (got a big crack in my exhaust header not to mention whatever is causing my car to run really rich)
2142 knock sensor 1 (resistances are same for both my sensors and it has continuity to the the ecu connector)
I pulled the connector off the ecu and tested its pins to the specs in the bentley manual. Here I found a couple things;
Idle switch closed the resistance is high at 4.5 ohms
Air flow sensor potentiometer between pin 23 and 26 I found resistance to be double the acceptable value. Got a reading from 7000 ohms and as high as 14000 with no change in test conditions...
Knock sensor 2 I wasnt able to get continuity, was a little confused since I originally got a code for sensor 1 not 2.
Is it possible the potentiometer or the idle switch could be causing these types of issues?
If not my next plan is start checking fuel pressure, and possibly get a timing light and make sure I installed the distributor right although I dont see why its not correct right now.
All input is appreciated, Ive done my fair share of searching up this issue but havent found something thats worked for me yet, anyone?
Things Ive tried:
New cts
Checked fuses
Tested csv
1111 defective ecu
1231 speed sender
