UPDATE: spent 1 hour trying to start the car today and wouldn't start. had fuel and spark and checked timing. replaced plugs to and still no start. well then I realized that I never took the cover off the turbo so the system wasn't getting air because I installed the piping so its a closed system now. LOL
:banghead::banghead::banghead::banghead: well after removing the plastic cover it fired right up and I moved it down the street.
going to be replacing the headgasket tomorrow with 2 ABA headgaskets. was going to do stock compression at 10psi and when I wanted to go higher run E85 but I had the head machined so its higher then stock because it was warped. so tomorrow the headgaskets should be replaced and I have some 80lb injectors coming in so i'm going to drop those in with octane booster.
