1 - 4 of 4 Posts
The car is a 90 Corrado, the donor was a 92 Corrado. I have most of the wiring done, but there two loose wires that I cannot account for despite scouring the bentley.
The first, blue wire with white tracer. Comes through the firewall grouped with the wires that go into 'S' in the back of the fuse box. Does not go into the fuse box, instead has a single plug on the end of it.
The second, red wire that comes out of the guage cluster wiring harness. Terminates into single plug.
Another question, are all of the wires that come out of 'D', on the back of the fuse box, simply 'switched' power wires for various accessories?
Thanks in advance.
Re: 92 VR6 swap, a couple of loose wire ?'s (PhantomDubs)
Blue/White stripe is for Vehicle Speed Sensor,connect to terminal box with other Blue/White stripe of same guage.
Red wire coming from Instrument cluster harness is not used.
Re: 92 VR6 swap, a couple of loose wire ?'s (RPTOFNDR)
nice http://****************.com/smile/emthup.gif
1 - 4 of 4 Posts
