93 Oct boost spike? what the?
783 Views 10 Replies 6 Participants Last post by  yoVWmon
APR 93 Oct boost spike?
Buddy of mine just had his 2002 GTI APR chipped. He has a boost spike that goes to 20psi? I have a 2001 GTI with the same chip and 93 Oct and it doesn’t spike to 20psi. What’s up with this? Did APR add the spike to the 93 Oct program or what?
[Modified by yoVWmon, 2:54 PM 2-10-2002]
See less See more
1 - 11 of 11 Posts
Re: 93 Oct boost spike? what the? (yoVWmon)
If they did im going back for a update
I see spikes of 1.3 but for the most part it is 1.2-1.25 bar.Is this 20psi spike all the time? or just now and then?
See less See more
Re: 93 Oct boost spike? what the? (20VsilvrGTI)
i spike to 19-20psi in a giac AWD
quote:[HR][/HR]If they did im going back for a update
I see spikes of 1.3 but for the most part it is 1.2-1.25 bar.Is this 20psi spike all the time? or just now and then?[HR][/HR]​
The boost will spike in all gears 1st - 5th all the time. He has an AWP motor and has only had the car for a week. Does anyone know whats going on. Did APR change something?
[Modified by yoVWmon, 2:55 PM 2-10-2002]
See less See more
That does not sound right at all. I only spike high in 4th and 5th gear.1st and second should not be anywhere near a bar.3rd may hit a little over a bar but not 1.4 .Sounds like a mechanical problem.Where is the Boost gauge tapped into?
APR dumped the spike for a wider powerband. Mine now spikes at 19-20, drops to 15-16 and holds till it starts to taper to 10.
And your old 91 program with a spike has been overwritten w/an improved 91 program as well.
And APR's tendency is not put the old programs back on. You can work w/them if you just have to see a 23lb reading, but it's not their norm.
Re: 93 Oct boost spike? what the? (Jman5000)
The vacuum hose is run to the fuel pressure regulator just like it is in my car. I am positive that he has the 93 Oct program, Tom and Brian at ECS Tuning burned the chip for him. What it does is a shoot up to 20psi then falls to 16psi it will hold there for a bit before slowly falling to 10psi. My AWW will sometimes make it to 17psi but mostly holds 16psi through the power ban. When I had the 91 Oct program I would spike to 21-22psi then fall to around 14psi. Do you think it is possible that APR might have sent the 91 program to Tom by accident, from what I have seen so far no one has a boost spike on the 93 Oct program.
[Modified by yoVWmon, 3:26 PM 2-10-2002]
TTT
that is a possibility. Have then do the chip again.
Re: 93 Oct boost spike? what the? (GTeeEYE)
I spike to 23psi with my GIAC K04 chip.....
Re: 93 Oct boost spike? what the? (drm916)
If you have a GIAC chip please do not post we are talking about the APR 93 oct program.
1 - 11 of 11 Posts
