1 - 4 of 4 Posts
I have a 93 Passat VR6 and Im having some problems with the A/C that I cant figure out. The system is charged with no leaks but the compressor will not kick on. You can turn the compressor so I know it isnt locked up. I replaced the fuse block under the hood, checked the switch on the dash(radiator comes on with the switch), and have checked out the wiring. Any ideas?
Discussion Starter · #4 ·
Re: 93 Passat A/C Compressor Problem (96wagon)
Fuse under the dash was fine. I have voltage to the compressor when the switch is turned on, but the clutch doesnt "click" or engage.
1 - 4 of 4 Posts
