1 - 9 of 9 Posts
Discussion Starter #1
Every part is OBO and everything must go but please keep
you offers reasonable, thank you. Also all agreed upon prices
must add %3.5 for paypal fees. There are no exceptions.
New build parts:
3. New black leather urS e-brake boot-
4. New air leather urS e-brake handle- $70 shipped for both OBO
11. USCAR to EV14 injector adapters- $25 shipped
12. Dealer/factory serpentine belt for urS cars without A/C.
Perfect for those doing an a/c delete. Price is $100 shipped
All of the used parts:
1. AAN water manifold- $65 shipped
2. AAN fuel rail with braided line, FPR still on it and a newer bosch fuel filter- $100 shipped
5. AAN motor mount bracket set- $65 shipped
6. Good factory upper radiator hose- $40 shipped
7. urs4 orange corner lights- $35 shipped
8. Another good CBD PJ 1st gear 5 speed 01e- $450 shipped within CONUS
10. Good urS locking rear end- $250 shipped within CONUS
11. Set of OEM GKN urS axle cores- $250 + shipping for all 4 or $75 + shipping per axle
12. x2 OEM driveshaft cores- $65 + shipping via greyhound (both need new cv's & center bearings)
15. Stock AAN K24 turbo NO shaft play and one broken exhaust stud- $125 shipped
Still useable!
17. ECRU rear seat back in good condition- $150 shipped via greyhound
18. Stock AAN wastegate & flexpipe- $100 shipped
20. Nice ECRU rear deck with good speaker grills- $150 shipped via greyhound
includes adapters for aftermarket 6x9 speakers - Sale pending
24. Box with every relay, fuse, and module from a 95.5 urs6- $125 shipped
25. Good 95.5 ABS pump- $125 shipped within CONUS
26. Good 95.5 ABS computer- $57 shipped within CONUS
Also have a 93 s4 abs computer- $57 shipped
34. AAN oil cooler assembly- $100 + shipping
35. AAN air box assembly- $75 + shipping
37. urs4 doors, no trims, (some surface rust)- $100 + shipping per door or $750 shipped for all 4 via greyhound
Very minor rust but overall in very good shape. Great for replacements
38. urs4 rear bumper in good shape, trims intact, just needs to be resprayed- $350 shipped via greyhound-- includes all 3 trims and bumper shocks
40. Good set of ECRU door cards- $200 shipped via greyhound
41. Good set of 94' urS window motors- $125 shipped within CONUS
44. USED 94' urs4 factory brake booster- $115 shipped
45. USED 94' urs4 clutch master & slave cylinder set - $115 shipped
Master is factory and the slave I have a factory boge unit
47. Good brake pedal- $50 shipped
48. Good gas pedal- $50 shipped
52. ZF factory rack & pinnion/suggest a rebuild but might
be able to get away with just a new boot & fluid-- $150 shipped
55. Front subframe- $50 + shipping via greyhound-- Shipping will between $50-$100
65. rear subframe- $50 + shipping via greyhound---Shipping will be between $50-$100
71. urS 26mm front sway bar- $50 + shipping via greyhound Shipping should be around $50
72. urS windshield wiper arms with good blades- $70 shipped
74. power steering reservoir includes cap, sensor, and wiring pigtail- $65 shipped
76. Strut tower covers/caps (good condition)- $57 shipped
81. Good charge piping hoses- $100 shipped within CONUS
1.OE factory throttle body hose
2. OE factory turbo outlet hose.
88. Good o2 sensor- $40 shipped
89. Good factory coolant tank comes with cap, sensor and plug with wiring pigtail- $50 shipped
90. Mint black rear view mirror- $57 shipped
94. Black mirror caps- big driver & nemo $57 shipped
97. Good factory front strut mounts- $57 shipped for the set
These are the oem ones that the bushings don't pop.
99. Stock rear diff mount- $40 shipped
100. Rear diff crossmember- $50 + shipping
101. whole center console switch board with all switches -- $100 shipped
104. AAN valve cover- $75 shipped
106. AAN rear main flange in mint condition. Sand blasted and powdercoated silver- $50 shipped
107. AAN power steering pump bracket- $50 shipped
Lightweight 95.5 aluminum version versus the 95<
cast iron unit.
108. Idler pulley & accessory bracket- $100 shipped
111. Nice black urS4 center console both pieces- $200 + shipping or $100 per piece
114. Black dash pads pieces underneath & glovebox- $100 + shipping
115. Black door sills and kick panels- $100 + shipping
This list is really all I have left but feel free to inquire.
cheers
Discussion Starter #4
South Florida,bump. Just FYI I
can ship anything you need. I just
shipped an 01E transmission to Minnesota
last week and an AAN engine to New
York last month.
I'm interested in the rear diff mount + rear subframe + rear diff carrier + strut mounts shipped to 53066.
1 - 9 of 9 Posts
