1 - 12 of 12 Posts
topic explains it all, it leaks pretty fast ill be in the driveway for like a half hour and there will be a little pudle when I leave...I tightened up the plug pretty tight I think but it is still leaking...what is goin on here?
Re: (DOHCVR6)
i dont know, i just kinda have been ignoring it for the past month
i probably should get around to looking at it, but i have too much other stuff to worry about
Re: (dubstylee)
Yea I see where you are coming from, do you add oil every once and a while or what?
Re: (DOHCVR6)
here is what you do, you drain ur oil, take the pug out and if there is a metal gasket around i then u replace it, if there is no metal gasket around the drain plug u buy one for it, or you can just buy a whole new plug and gasket
Re: (DOHCVR6)
From the drain plug area......did you replace the washer on the drain plug at your last oil change? If not, then you should every time you change the oil.
Re: (VikingVR6GTI)
Quote, originally posted by VikingVR6GTI »
yeah i am almost 100% positve that is my problem, i bought a cheap-ass fram filter for my VR, and it didnt come with a replacement crush washer
i have 3 OEM filters and washers in the garage from potter's, so i will get around to that next time i change my oil in a week or two
Discussion Starter · #12 ·
Re: (TrueDubFan)
I bought a new plug and it came with a rubber gasket...do I take the metal washer off the old plug and put it on the new plug along with rubber gasket?
1 - 12 of 12 Posts
