Yesterday let the vacuum sit on the system, put in a used a/c compressor, filled up and this morning after about 10min of use i do my part in destroying the ozone.
I appears the leak is right at the bottom of the redrier, my question is what is that brass looking fitting with the pin-hole at the bottom of it? Does it some sort of pressure valve if it gets too high?
I put in new o-rings when I put the condenser in.
