1 - 3 of 3 Posts
Ok, so I finally removed most of the a/c and lines from the car. But now, I want to remove the evaporator. I've been told that it is easily accessable after removing the glove box. What are your thoughts?
Cheers
Re: A/C Evaporator (dubbinitsins86)
You have to remove the dash, and the kneebar, and then yank the water hoses off the heater core, then you can get tothe evaporator, by undoing the 3 to 4 clips holding the box together.
Don't forget to plug the holes where the hoses run in from the firewall.
1 - 3 of 3 Posts
