Hey Guys, looking for some opinions as to what could be the cause of the following problem. Stock 2003 24v with 100K.
Like to point out the slightly annoying and humorous coincidence that this starts happening after my extended warranty finished at 97K...go figure :banghead:
Symptoms/problem:
1. Intermitent Whining noise while A/C is on and ONLY when at idle. Whining noise is not a steady sound level, but will slowly come on and then slowly go away.
2. Whining noise is Louder inside the car than outside.
3. When this happens, the A/C clutch seems to disengage and the A/C starts blowing warm.
4. Doesn't sound like a loose belt (not a screeching sound), as I know that distinct noise and as I mentioned, it is louder inside than it is outside.
When the noise occurs, it will go away if I rev the engine, start driving, or turn off the A/C.
After I start driving, A/C will start blowing cold and it works perfectly. If I just rev it, the noise will fade/go away but the A/C will not always start blowing cold. After driving with the A/C working fine, If I come to a stop again, it is not guaranteed to start again, but it is happening more frequently.
I have been told it could be the A/C clutch going OR it could be the Belt Tensioner pulley/bearing or the entire Belt Tensioner Assembly needing replacement.
I ‘m kinda leaning towards it being the Belt Tensioner Assembly as it is strange that if I rev it the sound goes away, but the A/C could still not blow cold , but once I actually start driving the A/C will start blowing cold like normal. It is almost as if at IDLE there is not enough tension on the A/C to make it rotate properly to blow cold and then cause the weird noise or something??
I would appreciate some of your insight guys. Just trying to save myself some money and pinpoint which piece I need to replace.
Thanks :thumbup:
Symptoms/problem:
Thanks :thumbup:
