a/f gauge wackiness
499 Views 2 Replies 3 Participants Last post by  AAdontworkx3
ok-hooked up the a/f gauge yesterday, tapped into the gray wire on the o2 sensor (obd1 aba), started car, stayed rich the whole time thru the rpm range...hmmmm, ok- tinker with the connections-barely registers lean thru the rpm range, now the big ?- do you guys ground to the engine or to the chassis? destructions say to ground to the engine, but i've heard of people going to the chassis, and thoughts???
See less See more
1 - 3 of 3 Posts
Re: a/f gauge wackiness (hkk735)
I grounded mine to the chassis, A/F bounes like a rubber ball....make sure your voltage is up, when voltage gets low they tend to act wacky (lean mostly, you'll loose some bars)
Re: a/f gauge wackiness (PAGTI91)
ya same here... maybe ill try grounding it to the engine though. i get the bouncy ball too
1 - 3 of 3 Posts
