1 - 4 of 4 Posts
· Premium Member
Hi turbo guys, for the sake of self education - could someone please explain 2 things to me - what's purpose does it serve to monitor EGT and also - when someone has like a T3/T4 with super 60 trim - when does it mean as far as the turbo goes ? Thanks alot.
Re: A little education please (WolfGTI)
EGT's when to high will warp the turbine shaft causing turbo failure. It also lets you know if your running lean or too much boost. When someone says they are running a T3 or T3/T4 it means that they have changed the stock K03 turbo which comes on the car and replaced the stock manifold with a manifold for the Garret Turbos. So basicaly they've swapped turbos to a much more efficient one.
· Premium Member
Re: A little education please (Bug_Power)
Thanks for the infor as regards EGT. - I was aware that running a T3/T4 means they changed from the K03/K04 they originally had - what I wanted to know was what does the Super60/70 trim mean for the turbo.
1 - 4 of 4 Posts
