Ok, we received this little fellow in our garage... maybe we will keep it... but we have a little problem...
It has a heavy modifyed 2.0 engine NA, when the car is at Neutral gear it revs perfectly, but if you are in any gear (engine builds load) car looses power for a couple of seconds and then takes off!! this also happens when gear shifting... all this in hard acceleration.
if you push the pedal gradually it takes off ok...
With Vag Com we see that the throttle position is backwards???... yes. with no throttle says 75º sh, with full WOT says 0º !!!! is this reading correct for that old ecu? is a 06M 90 60 22
any help?
any help?
