1 - 20 of 185 Posts
:wave:
I'm back! Here is my second technical build, aptly named "A very technical build - PART II"
I kept the naming the same because i am keeping almost the same basic concept of a trunk layout, just adding a few tweaks here and there based on stuff i liked and didn't like from the first setup; and yes there were a few things that i didn't like.....
First build for the new guys reading: http://forums.vwvortex.com/showthread.php?5238122-A-very-technical-build
Problems with the first build:
- Hard to get at relays
- Wasn't very "showy"
- didn't actually get around to the subwoofer & amp install so it will be documented here
- Tight for wiring
- Lines under car need to be protected a bit more for my liking in these Canadian winters
What I wanted to add/change:
- Change location of water trap (1)
- Add water trap before the buffer tank (3)
- Add another OB2 compressor (2)
- Move the compressors closer to the tank (4)
- Add more storage room for air tools, spare parts and on the road fix it solutions for ease of road trips (6)
- Make it so that i can drain the water traps and tank without having to air out at all
So to resolve all of the above issues/wants i devised a plan (as usual :p)
Framing system
- Change frame mounting for compressors
- Lower 3 gallon buffer tank and compressors enough so that i could fit a 3” tall floor compartment for storage right above the tank and compressors
- Move the compressors forward on the frame a bit
- Install shut off valve between tanks where the original water trap was located (1)
5 Gallon airtank box
- Add water trap between tank and manifold (7)
- Make false floor to hide all wiring and plumbing for showing off the tank from back seats (keep in mind that there is a false wall hiding the 5 gallon tank from the trunk)
- Add inflation valve to tank just incase something happens
Electrical Connection Box
- Add extensions for compressor relays, cutout through wall so they are accessible from the trunk electrical box instead of below the false floor behind the air tank
- Add amplifier for sub
Okay so here is where the fun begins......
Installed removable connection points (will be moved to the bottom of the frame) so that they can be easily replaced. Needed for the increased weight of all the compressors. They are probably 100lbs for all 3 of them with the frame, good thing i have e-level!
Drain valve on the bottom of the tank with ball valve – easy to drain and will be routed directly out of the trunk through the bottom
Compressors and tank closer together and top at around the same height
Frame redesigned, built, but not fitted in the car yet
Keep looking for updates!
:popcorn:
can't wait to see the outcome this time! I know Ben from RI had some trouble battery/alternator wise when he ran 3 vlairs, is the power used by these more efficient or do you have plans to support the power consumption. I never thought it would be a problem, but maybe its just a myth / weird coincidence.
200A alternator from EA :thumbup::thumbup:
It is a DEFINITE if you are going to be running more than 1 of them since the amp draw on each is 35A
Discussion Starter · #7 ·
thats great info to know :thumbup::thumbup:. Does that alternator swap right in as well?
Yeah it is a direct bolt on replacement, he makes them custom for what you want. This one i have is 200A @1200rpm and 150A at idle (750rpm)
Discussion Starter · #10 ·
yes i :heart: your builds. Could you share how your wiring the three comps? everywhere i looked i have only seen dual diagrams, just curious.
:popcorn:
i will do up complete plumbing and wiring diagrams including my self latching automatic resetting relays and turn off switches for the compressors :thumbup::thumbup:
Hey, Mech, I'd also like to know where you got that alt from (Excessive Amperage?), since I want to go bigger than stock at some point.
Glad to see you're back in the trenches, BTW.
EDIT, nevermid, I just saw the Excessive AMperage sticker on the pic of the alt you took. Duh.:facepalm:
Discussion Starter · #17 ·
how much did that alt run you if you don't mind me asking.
Give EA a call and they will give you a quote :thumbup:
:thumbup: love that this is back
:) Me tooooooooooooooooooooooo
:popcorn:can't wait to see more
:thumbup::thumbup:
sweet! I really wanna redo my trunk. Looks ****ing horrid! Can't wait to see yours:thumbup::thumbup::beer:
Let me know and i might be able to help you out if you are ever in Calgary
:laugh:
Super nice build! Really like the noise isolation setup. :thumbup:
:thumbup::thumbup:
Discussion Starter · #18 ·
:popcorn:
As promised a full plumbing and wiring schematic, any questions just ask.
WIRING
Okay i have decided to do some funky unnecessary wiring here to gain what i feel is a freakin fantastic functionality. Functionality goes as such:
- Turn on car
- Car will raise automatically due to e-level
- Press kill switch to shut off each compressor individually (or maybe all 3, haven't decided yet)
- Compressor will stay off until button is pressed or car is turned off
- If button is in the ON position (working/not lit up) when the car is turned off the switch remains in the same position
- If the button is in the OFF position (not working/yellow light showing) when the car is turned off it automatically resets itself so that when you start the car the compressors will turn on again.
This auto-resetting is fantastic for if you have just a plain toggle switch and forget to switch it back on and all of a sudden you have zero pressure in your tank. The buttons are OEM Euro switches just like the following "funk" switches found on graeme86's webpage http://www.users.on.net/~graeme86/funk/funk.html
They have a brilliant mounting spot that is out of the way and will look extremely OEM.
The wiring diagram is entirely complete except for the wiring of the actual button which is just three lines on my schematic. Here is the internal schematic, just connect 4 and 6 to grounds, 3 to your dimmer switch, 1 and 2 to splice between your line that you want to activate, and 5 from the SPDT relay NO port (87a). This SPDT relay is used purely to get the yellow light to activate when the compressors are in the OFF position and not working, which is the way i want it
Ahh, it's so nice to see someone doing an install that actually PLANS AHEAD as opposed to winging it, like many of the build threads on the Vortex seem to imply (I could be wrong, just an observation via the internet):D.
Yeah, making diagrams/CAD drawings can take longer, but it also causes less headaches or rebuilds.
Well done, sir.
1 - 20 of 185 Posts
