Lookin' pretty good so far. Hope this turns out to b what you really want. :thumbup:
Should be :laugh:
MINI UPDATE
Got my water traps on shut off valve. Shut off valve will be extremely handy because with the e-level setup if you relieve pressure from the air manifold the car lowers itself and airs out the bags too. This way i can empty my water traps and drain my 3 gallon tank without having to lose all of my air. This way it is also quicker to get back up to full pressure (not that it will take long anyways)
I am again running flex airlines directly off of the compressor. IMO the OB2 compressors don't get hot enough to do any damage to the airline, if it happens in the future i will worry about it at that point.
Everything is almost ready to install, just have to get quick disconnects for the wiring harnesses of the compressors so that they can be easily detached from the relays and its going in :thumbup::thumbup:
JIC-FNPT adapter, then MNPT-PTC adapter, all 1/2"
All 3 compressors tee together and lead into this one water trap on the side of the tank. 1/2"PTC-3/8"MNPT adapter
Outlet from 3 gallon tank to 5 gallon tank
