Re: A2 Jetta--amp under rear seat? Sub install? (SeattleGLI)
SeattleGLI,
We have a '88 GLI. When we first got it back then, we had an A/D/S amp installed in one of the wells you are speaking of. We had no problems with it that I can recall. As you can imagine, there is virtually no venilation in there, so I wouldn't recommend it for a high-power amp.
When I upgraded the stereo 5-6 years later, I had them (Magnolia Hi-Fi installed both systems) mount the new, larger, amp on the back of the rear seat so it would have better ventilation. We never had a problem with that installation, either, even with a trunk full of camping gear. If I were you, I would seriously consider this mounting location.
Good luck whichever way you choose!
I don't have the ski pass-through (nor is there a sub in our Jetta), so I can't answer your other question.
Brian
[Modified by MojoMan, 9:41 PM 11-24-2001]
SeattleGLI,
Brian
