1 - 16 of 16 Posts
I have the possibility of buying a 1987 or 88 scirocco this spring. It's a really good looking white scirocco with a 2.0l 16v engine 1.8l head, shrick and oettinger cams, header, exhaust, no rust, p&p, blueprints, the engine bay is sooooo clean, it's a beast. anyway, I dont know anything about the scirocco chassis, do can you talk about it please, what are the pros and cons and please be objective
As you can see I had a jetta so you can make some comparison with the A2 chassis (also can you tell me is I write chassi correctly in english)
thx a lot!
Re: A2 or Scirocco? (Aw614)
I love my Scirocco. Mine is a different body style than the one you are looking to buy bet has the same Chassis.. the Scirocco's are made on the A1 chassis like the rabbit. My rocco is definitly more fun to drive than any A2 that I have had so far. I cant think of any cons right off the top of my head. It has the same mechanical problems an A2 would have I suppose. It is a VW
Re: A2 or Scirocco? (QcGTI)
quote:[HR][/HR]c'mon some cons please!
[HR][/HR]​
I still bump my head getting in the car occasionally.
The rearview mirror gets knocked off easily.
GTX16V/GTIVR6/A42.8QMS
Flashsilver/Tornadored/Melange
Discussion Starter · #12 ·
Re: A2 or Scirocco? (The Pit)
well, thank you very much! if I have enough money I will probably buy it! It's one the most beautiful scorocco that I have ever seen and the only white car that look good!
2006 LS430, 2012 GX460, 2005 ES330, 2018 Explorer PI
Chicks love guys with Sciroccos... though it's hard to get any love in the back seats because there just ain't no room...
Great cars though!
From your description, the Scirocco you're looking at isn't exactly stock - in that case, if you're ultimately looking to modify your car, it's probably your best option since it's already been done. My "stable" includes both an '88 16v Scirocco that's prepared for the Grassroots Motorsports challenge and a '87 16v GTi that's prepared to SCCA's IT specs. Therefore, my opinions are biased towards performance and not an emotional attachment to exterior design. SO if you're a Scirocco fan b/c it looks cool, read no further.
However, bear in mind that the Sciroccos (or any A1 chassis) isn't the best design effort that VW ever put forth. In fact, the only saving grace to the 16v Scirocco is the lower suspension tie-bar which is still a far cry from the sub-frames that were standard on A2s. The A1s are markedly lighter than the A2s (except for the 16v Scirocco which weighs in roughly the same as an early A2 GTi 16v) which means that the car feels more like a go-kart. While the weight advantage of the A1 makes the car more nimble, suspension design and chassis flex without a cage make the car less stable in heavy cornering. The last issue with any A1 chassis car is the motor mount design - from what I can discern from these digests, the A1 chassis isn't capable of handling more than about 175 hp without significant chassis reinforcement. Even in stock trim, the motor mounts are a "normal wear item" just like the mounts in the 944 (VW's bigger and more expensive brother). On the plus side for stock 16v Sciroccos are the 10.1" brakes which make a relatively heavy car stop quite well. Furthermore, due to the lower roofline, the centre of gravity is lower which aids in cornering.
The A2 cars are heavier by 200-300 lbs. With that extra weight comes some added track, a front sub-frame and a more logical and durable engine mount system. While the A2 isn't as nimble, the added track and superior suspension design give the car more stability, even with the higher center of gravity (which can be offset by lowering the driver in the chassis). The biggest negative to an A2 are the miserable 9.4" brakes - the SAME brakes that were fitted on the A1 GTis!!
Both cars have their specific strengths and weaknesses. In my case, I'd been searching for an A2 GTi 16v to use as a commuter car but happened upon the '88 16v Scirocco instead. While not being a fan of that genre Scirocco (I prefer the Mk1 but that's another story), I must say that the car has impressed me with it's appearance and fairly sedate ride. The '87 16v GTi is also a decent car although I can't say that I'd be as impressed with a base-model without the accoutrements that are included with the GTi/GLi - interior, 4-wheel disc brakes and so forth. Suffice it to say that the Scirocco is nice looking and a relatively comfortable commuter car, the GTi is a decent basis for an IT car with good availability of go fast bits.
In this case, if the Scirocco described is the one you'll purchase - buy it instead. It sounds like it already is chock full of parts that are (hopefully) already sorted.
1 - 16 of 16 Posts
