As title states, I am curious as to what is meant by the following information found in the FAQ. I am using a complete 93 Passat VR for my donor, and realize i need 100mm axles. I was wondering if the following would work with my setup. 89 Jetta 16v 100mm axles. i am keeping the 4 lug BTW. As far as the control arm setup and hub assembly is concerned, will this work with the 02A Transmission? Thanks
IN FAQ:
Axles:
*driveshaft choice is dependent on which control arm / hub assembly is used, axle length and splines are different from 4 lug to 5 lug
a)any A2 100mm *4 lug
b)corrado G60 *4 lug
c)A3 2.0L *4 lug
d)A3 VR6 *5 lug
e)Corrado VR6 *5 lug
IN FAQ:
Axles:
c)A3 2.0L *4 lug
d)A3 VR6 *5 lug
