1 - 2 of 2 Posts
How would I go about doing this? I've been searching the forums but can't get a clear answer...any websites? I'd like to be able to use the 5x100 wheels from the newer dubs on my A2.
Thanks,
Teren
1990 Corrado G60
Re: A3 Brakes into an A2??? (poshvw)
The easiest and most straight forward that I know is to use the plus suspension setup from the 5 bolt Corrados.
This is virtually an A2 with the wider stance. Many A2s have been doing this as an upgrade. The rear discs are interchangeable however the fronts will require some suspension changes considering the different offset of the 5 bolt rotor.
Then you can select wheels that are offset to the VR6 Corrado.
Anyone else elaborate further?
1 - 2 of 2 Posts
