Quote, originally posted by drew138 » |
Is there a reason that you didn't just run the power to the LEDs from the foglight itself? Can you get a 12v line from the fogs? Seems this would be the easiest thing to do? |
Thanks. Makes sense. I just got the LEDs today and they are pretty bright. They look waybrighter in your pics, but maybe its because you've got 7 on each side! Did you play with the exposure at all on your pics? Also, now that I see the actual lights and looking at your fog housing -- you drilled the hole and then 'dropped' the LED in from the front of the grill, rather than "pushing" the light from behind. Is that correct. Now I need to get me a 'test' sline housing. I've a few ideas that should work, just not sure at this point I want to 'test' with my own housing as it could go drastically bad!!!!! Drew |
Quote, originally posted by tiptronic » |
Goodluck on the Sline Grills- hopefully you can pull it off and be able to share with the other S liners ![]() |
Quote, originally posted by brungold » |
yes please! i'm eager to do this, but can't see a good place to mount them on the s-line. ![]() |
you did see my mock-up sline photoshopped ''leds'' photo? e |
I'm thinking that I can get them in that cross bar section rather than under them. There is some room in there, but it will be a tight fit with all the wires. . |
hey e, so you tapped into the parking light for power? so just to make sure.. LED -> parking light fuse -> interior switch? also, can we see the switch you are using in the interior? sorry for the noob electrical questions.. my buddy with a black non-sline is going to order the LEDs and give this a shot. any chance we can enlist your help? we'll bring beer ![]() |
Quote, originally posted by VUUR32 » |
Has anyone tried the S6 LED's on an A3? http://oempl.us/index.php?main...d=451 I'm not sure if they'd fit? http://www.r32-club.de/showthread.php?t=9134 |
Quote, originally posted by m32 » |
Just want to thank Tiptronic for doing this and giving me the idea for the same thing on my Porsche. Those LED's are worth the money |
