A4 R32T swap
Hey guys.
I have had a few people asking me about my swap so I am posting some pictures for those who want to do this.
It was a rather easy swap with alot of parts that did not fit, had to be made or broke down after first test drive
Found a cheap R32 engine from ebay in UK..... it had been stored outside for a while so it was not in a good shape.
Engine block had a few rusty cylinders so I had to bore it 0.5mm overdim.
Engine mounted to gearbox with Touareg adapter in between.
custom engine mounts.
Cylinderhead on and turbo on. modified Holset HX40
Custom intake:
Modified oilfilter housing with thermostat oilcooler adapter.
Coated manifold+housing. Also dropped in a 44mm wastegate.
Hood clearance
Had to modify hood and top of engine for it to fit.
Also modified the subframe so I could lower the engine max.
Modified by turbo_fb at 11:38 AM 3-21-2010
Hey guys.
Custom intake:
Hood clearance
