1 - 20 of 47 Posts
Re: ABA 2.0 bottom end in 1.8L. Worth it? (Batan)
It doesn't seem that for the amount of money and time it takes to do one of these swaps that it is really worth it. You only gain something like 10-15 HP and maybe 15 lb-ft of torque? If you are going to do a swap, I would say make it worth the time and effort. Throw in a 16v, or a G60...these engines are fairly easy to find and not too spendy. The G60 is already built for boost and would be a great building block as would a 16v. You may even look at a 1.8t or VR6 if you want to spend a little more. Thats just my opinion and I am sure I will get flamed for it, but oh well.
[Modified by 8vGTI, 9:30 AM 11-27-2001]
Re: ABA 2.0 bottom end in 1.8L. Worth it? (8vGTI)
I've read stuff about ABA swap and it sounds a lot easier then doing 16V or anything else. No major wiring, no ECU or fuel injection swaps...sounds a WAY easier. I'd love turboed 2L 16V though.
Besides, wouldn't ABA engine with P&P, good exhaust, cam etc. be in 150HP neighbourhood? And then turbo that and ....whoa! IMO
[Modified by Batan, 10:06 AM 11-27-2001]
I started with a GX engine (85hp, 96ft-lbs) in my 87, and I changed the exhaust and engine, using a ABA block, an 86 GLI head and manifolds, and a TT exhaust.
I'm still thinking there is a little more hp to be had, but when it was on the dyno, it made 104hp and 122ft-lbs, at the wheels.
I was able to retain the GX engines fuel and ignition systems, and get those numbers. Since then, I have wired in a KS ignition, and it seemed to help some.
If I went full x-flow, 16V, G-60, or VR6, it would have been far more involved than just sticking in a ABA block. I would have had to changed from CIS to Motronic or something, much more wiring would have been involved, and I'm sure the prices for those engines and the parts are more than my plain 8V engine. Bang for the buck? I'm not sure...I've never driven one of those cars, and I'm not sure how much it would have cost me to do that swap into my car. For my swap, I have between $1500-$2000 in it total.
Anyway, any swap will net you more power, I guess it kind of depends on your budget and/or ability
Broke
I understand that other swaps may be more difficult but it just seems a bit excessive to spend that much time and money on 10hp.
Im sort of confused about this one. Which 1.8 head do you use? I mean, dont nearly all of us have 1.8 heads in our cars as it is, and therefor wouldnt it be fairly simple to just change out the bottom end compared to swapping the entire ABA for LESS power? Cause Ive got a 1.8L GTI (california digifant one, though) that could use a few more HP...
Re: ABA 2.0 bottom end in 1.8L. Worth it? (GTI666)
its worth it if you are looking to beat 90% of the honda boys (not preludes or type r's, but mildly modded si's, gsr's and accords and stuff) its a worthwile swap. if you arent looking to go turbo or s/c its definatly worth it. i beat 2l 16v's with my swap too (272 cam, lightened flywheel, catback exhaust, 9a tranny, k&n) and i DROPPED this kid in a 2000 gti vr6 (on a back road) so dont underestimate your 8v. i did, however switch to a crossflow so i can go turbo...
-andrew
Re: ABA 2.0 bottom end in 1.8L. Worth it? (Andrew Foss)
The ABA is worth it with the right cam and head. If you are using CIS, a Schrick 288 will wake up the beast very nicely, putting you equal with a midly modded 16v(exhuast and intake) and will keep the torque somewhat. Overall, for the person on the budget, is totally worth it. http://****************.com/smile/emthup.gif
quote:[HR][/HR]I understand that other swaps may be more difficult but it just seems a bit excessive to spend that much time and money on 10hp.
[HR][/HR]​
Umm... Try 19HP. Let's try this slowly. 104-85= what? HP isn't everything the torque gains are phenomenal for the money.
I have a friend that swapped an Audi 2.0L in. Worth every penny. Schweet ride. He dynoed 119HP at the wheels. He started out with a 79HP digifant. 40HP!!!
Llew.
Re: ABA 2.0 bottom end in 1.8L. Worth it? (G60Jetta2dr)
quote:[HR][/HR][I have a friend that swapped an Audi 2.0L in. Worth every penny. Schweet ride. He dynoed 119HP at the wheels. He started out with a 79HP digifant. 40HP!!! [HR][/HR]​
I like what I'm hearing!
What did he do to it?
So you are saying that all he did was add .2l and gained 40 HP!?! When I was looking at the swap when my car was an 8v everyone was telling me to expect around 115 hp and about the same for torque. Even A3 2.0's are only rated at 115 hp at the crank! Is there something I am missing or overlooking?
usually u do more than just the block. u port the head and stick on a dual downpipe if u don' thave it etc. i recall broke did a few more things.
i dont think that just swapping in an ABA is going to add that many horses. But with mods it will be a great improvement over the orignial motor. Take mine for example my original motor was a GX 1.8 with 85 hp. Now with the mods I have and the aba I have 147hp at the crank. Great improvement I think.
1 - 20 of 47 Posts
