1 - 9 of 9 Posts
i got a aba block i wanted to build for my turbo 16v, but it doesnt have the oilsquirters. is it even worth using?? cause if it isnt i could just keep my 9a in there.
Re: aba block? (twocamvw)
hey tim, i just got ur message...... it pisses me off, because this is the second obd 1 motor that i know of without squirters.....
wonder if its a specific vin related thing????
as we speak, a friend of mine in cromwell is pulling apart the bottom end from his 95 to see if it has the squirters........ its got me
Modified by laydback at 8:43 PM 6-29-2003
Re: aba block? (ValveCoverGasket)
im thinking it might have to do with the digits in the vin........ depending on where the motor was built..... i dunno im confused about the situation too
what is involved with a aba bock and 16 vavle turbo? are pulleys the problem? or is the timing belt the problem? if you use 2.0 16 valve pulleys they should go on correct me if im wrong, but will you have problems finding a timing belt that is 16mm longer, how about mating the aba pulleys to the 16 v head what problems are there if any? thanks
1 - 9 of 9 Posts
