1 - 3 of 3 Posts
I picked up a 96 Jetta with ABA 2.0 engine. Fails Secondary Air Injection flow test. Discovered that the ports are plugged where the exhaust manifold joins to the head. Is there any way to remove these plugs so I can have a functioning secondary air injection system and pass smog?
Or somebody replaced the original head with an OBDI head. If that is the case, the ports aren't even cast in it. And I'm not sure you could drill them. Might be easier to get a chip with it coded out.
1 - 3 of 3 Posts
