1 - 2 of 2 Posts
I was finally able to run a vag-com on my abs and this is the code it gave me... They suggested somewhere to try to cycle the abs pump. Anyone have any ideas what to do or could point me in the right direction??
01276 - ABS Hydraulic Pump (V64) 16-10 - Signal Outside Specifications - Intermittent
Re: ABS error (eclps)
Not sure what year your car is but my g-friends 2002 jetta had a recall on the brake pedal switch. I'm not certian but I think she had the same code. If your car is a 2002 or there abouts you may want to call your stealer to see if your car was part of the recall.
1 - 2 of 2 Posts
