So here lies the problem. I am the proud owner of a 2006 1.4 golf fsi
I had the abs light and esp light come on so I had the abs pump changed. The garage I took it to changed the abs pump and told me it needs to be coded which they do not do.
I ran a scan and have the following error code.
I also have the original abs pump part number. 1K0 907 379 AA CTA, 1K0 614 517 T
Wednesday,27,April,2022,18:20:12:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 21.3.0.0
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ1KZ6B095751 License Plate: S24 YYD
Mileage: 206520km-128325mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ6B095751 Mileage: 206520km-128325miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 03C 997 056 K HW: Hardware No
Component: MED 9.5.10 00 7502
Revision: --H01--- Serial number: VWZ7Z0E3038780
Coding: 0000071
Shop #: WSC 00046 412 16384
VCID: 356194D35C417F2320-8060
1 Fault Found:
008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
P2096 - 002 - Too Lean - MIL ON
Readiness: 1000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0023170
Shop #: WSC 00066 000 00000
VCID: 71E960C368A913033C-8024
4 Faults Found:
01044 - Control Module Incorrectly Coded
003 - Mechanical Failure
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
01423 - Lateral Acceleration Sensor (G200)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DP
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 75E154D31CC13F23E0-8020
No fault code found.
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000003719381
Coding: 008D0F2700041800001400001400000000087B075C
Shop #: WSC 00046 412 466944
VCID: 2A5BB7AF85FF20DBBD-807E
Subsystem 1 - Part No: 1K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 00046
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: 38 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD042L1V
Coding: 0013112
VCID: 3B7582EB7A65A953D6-806E
Subsystem 1 - Serial number: 6332MSME0D2C3663G
Subsystem 2 - Serial number: 6342MSME0C631F35H
Subsystem 3 - Serial number: 6352QSME03321E077
Subsystem 4 - Serial number: 6362QSME033B1F61I
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AE HW: 1K0 953 549 AE
Component: Lenksäulenmodul 634 0070
Coding: 0000002
Shop #: WSC 00046 412 1671168
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 952 G
Component: KOMBIINSTRUMENT VDD 1012
Coding: 0003403
Shop #: WSC 00218 067 57207
VCID: 2E53BBBFB9174CFB61-807A
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800105B228ADF
Coding: 3D0F0340070003
Shop #: WSC 00046 412 1187840
2 Faults Found:
01305 - Databus for Infotainment
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 254
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:23
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2312
Coding: 0000692
VCID: 366393DF4147743B29-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 00218 210 90024
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 00C802087F2D8405485B018010CC
VCID: 79F958E330D95B4384-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0000692
VCID: 377D9EDB464D8D3332-8062
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 01:24)--------------------------
Wednesday,27,April,2022,18:22:20:00009
www.Ross-Tech.com
Coding: 0000071
1 Fault Found:
Revision: 00H13001
Coding: 0023170
4 Faults Found:
Coding: 00063445
Shop #: WSC 00046
Coding: 0013112
Coding: 0000002
Coding: 0003403
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:23
Coding: 0000692
Component: KSG 0401
Coding: 0000692
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 01:19)--------------------------
Wednesday,27,April,2022,18:34:47:00009
www.Ross-Tech.com
01-Engine -- Status: OK 0000
Coding: 0000071
Readiness: 1110 0101
Revision: 00H13001
Coding: 0023170
4 Faults Found:
Coding: 00063445
Shop #: WSC 00046
Coding: 0013112
Coding: 0000002
Coding: 0003403
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:23
Coding: 0000692
Component: KSG 0401
Coding: 08C802087F2D8405485B018010CC
Coding: 0000692
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 01:18)--------------------------
www.Ross-Tech.com
Coding: 0000071
1 Fault Found:
Revision: 00H13001
Coding: 0023170
4 Faults Found:
Coding: 00063445
Shop #: WSC 00046
Coding: 0013112
Coding: 0000002
Coding: 0003403
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:23
Coding: 0000692
Component: KSG 0401
Coding: 0000692
Address 56: Radio
Cannot be reached
www.Ross-Tech.com
Coding: 0000071
1 Fault Found:
Revision: 00H13001
Coding: 0023170
4 Faults Found:
Coding: 00063445
Shop #: WSC 00046
Coding: 0013112
Coding: 0000002
Coding: 0003403
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:23
Coding: 0000692
Component: KSG 0401
Coding: 0000692
Address 56: Radio
Cannot be reached
www.Ross-Tech.com
Coding: 0000071
Revision: 00H13001
Coding: 0023170
4 Faults Found:
Coding: 00063445
Shop #: WSC 00046
Coding: 0013112
Coding: 0000002
Coding: 0003403
2 Faults Found:
Freeze Frame:
Fault Priority: 1
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:20
01304 - Radio
Freeze Frame:
Fault Priority: 2
Reset counter: 199
Mileage: 189514 km
Time Indication: 0
Date: 2000.00.00
Time: 05:13:23
Coding: 0000692
Component: KSG 0401
Coding: 0000692
Address 56: Radio
Cannot be reached
