1 - 11 of 11 Posts
Senior Member
Senior Member
Here is photo of the codes
check all of the sensors at each wheel to see if they, the sensor wheel, or the wiring are damaged.
as for the other codes, try a TB adaption. if that doesn't work it's possible you have a bad TB.
OR do you have a flashed ECU (upgraded SW)????
Discussion Starter · #10 ·
Thanks for your help man, you legend you!
Senior Member
Ok il be checking the sensors and wiring on each wheel.. What's a TB? No upgrade or flashed ECU.. Yet :)
TB = Throttle Body
in the FAQ's is a DIY (top of forum page is link) to how to perform a TB adaptation. do that, and clear the codes to see what comes back. :thumbup:
post up what happens next/codes if any
1 - 11 of 11 Posts
