Ok during the summer i installed my brembo big brake kit and i had to splice and combine the abs wires to i guess disable (or trick) the abs system and keep the light off. Everything worked fine. But lately when i drive (most noticeable on turns or hard bumps) the abs and traction control light came on and the brake light is blinking. Sometimes it goes off sometimes it doesnt. I checked the brake fluid and that was fine. I took the wheel off to undo and redo the wire and disconnect the battery to refresh the system. It worked for a little but it is happening again. I doubt VW wont do anything since theyre aftermarket brakes and im stumped. Help would be greatly appreciated
