1 - 3 of 3 Posts
Discussion Starter #1
Hi All,
With the onset of summer I am noticing that my AC is not working as well as normal. Is there anything an enthusiast can do to check the AC system or does that require special tools? I will be checking it in VCDS to see if anything is going on there but I don't have any faults / alarms on the dash.
TIA,
Troy
Should get your car hooked up to a AC Gauge set and check both Low and High Pressure with compressor running and compare to the specs and have somebody that is knowledgeable about AC tell you what is going on.
Just don't add refrigerant, that can be bad if not needed.
1 - 3 of 3 Posts
