Re: acceleration of 1.8T (jeffreynimz)
Hello Jeffrey - let me be the first to welcome you to the Vortex, and congratulate you on your purchase! Wagons are great, and Passat wagons are even better.
In reference to your query, many here will post that you should upgrade the OEM ECU chip, to allow greater boost values. While this will certainly solve your 'sloooow' acceleration problems, you may/may not wish to tamper with this delicate piece of your new car's fuel management system.
Passat's will seem slower than the boosted Jettas, primarily (as you mentioned) because of weight, but also gearing (if I'm not mistaken). Your wagon (Tip?) has a fairly tall 5 gear, but not a very torquey 1st gear. You'll quickly develop a feel for the acceleration characteristics, and adjust your driving style accordingly. I've found that a gradual yet strong depression of the throttle from dead stop yeilds better results than mashing the throttle (which you probably shouldn't be doing at all until your break in period is complete!)
On the other hand, if you notice greater slowness than what you experienced during your test drive, perhaps a problem exists with the blow off valve. Can anyone here shed some light on what could mechanically cause Jeffrey's car to drag abnormally? Whatever the reason, if there indeed is a problem - you are fully covered under warranty.
Lastly, remember that the Passat 20V (unless heavily modified) is not a drag racer. It is - however - a very stable and nimble car at speed.
[Modified by Bill, 5:20 PM 11-26-2001]
