Re: Acceleration problems. help need it !! (RAULTPEREZ)
bump
bump
Quote, originally posted by 20psirabbit » |
just an idea....... in the insttructions for the a\f ratio guages, it says to tap the signal wire on the harness side of the o2 wire plug, because some o2 sensors use shielded wire and it could give you problems. did you do that? i don't know if those o2s use shielded wire or not, just thought it throw an idea out there. hope you get it solved soon.
