All, started receiving the above code earlier this year and it has become more frequent. Until today, the last time was October 17, 2016. Code is primarily triggered during or after a rainstorm and results in CEL, EPC and limp mode initiation. Can still get up to 45 mph in limp mode so my daughter has been able to drive the car home on back roads without much problem. Last time I disconnected the battery, pulled and cleaned the MAF sensor, pulled and cleaned the ECU connection, reconnected the battery, cleared codes, ran two TB adaptations with Vagcom and called it a day. Car ran great until today.
Same story with heavy rains, CEL, EPC and limp mode initiated on my daughter's drive home from college. Ran a full autoscan, attached below:
Wednesday,26,October,2016,11:47:30:20196
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Data version: 20161010 DS267.0
www.Ross-Tech.com
VIN: WAUVT License Plate: 04 A4 3.O OCT 26 2016
Mileage: 148700km-92397mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUVT Mileage: 148700km-92397miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 D HW: 8E0 909 059
Component: JHM* V3/9X G 0003
Coding: 0016751
Shop #: WSC 63251 000 00000
VCID: 3669D6F7420999F256-515A
2 Faults Found:
18047 - Accelerator Position Sensor 1/2 (G79/G185)
P1639 - 008 - Implausible Signal - Intermittent
P1639 - 008 - Implausible Signal - Intermittent - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8E0 927 156 Q
Component: JHM VS2 3.0l5V USA 1213
Coding: 0001002
VCID: 3C7DC4DF7C2543A2A0-515A
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 3429
Coding: 04497
Shop #: WSC 01234
VCID: 264906B7C2A9E972E6-513C
2 Faults Found:
01314 - Engine Control Module
79-10 - Please Check Fault Codes - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1219
Coding: 00000
Shop #: WSC 63251
VCID: 63CF5FA3F11B5C5AC1-513C
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63251
VCID: 356BD1FB0F0F92EA5F-4B18
1 Fault Found:
02104 - Light Detection Sensor (G399)
29-10 - Short to Ground - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 3001
Coding: 0010607
VCID: 3777DBF3450360FA4D-513C
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenks·ulenmodul 0308
Coding: 02042
Shop #: WSC 63251
VCID: 3E79CED73A3951B28E-4B18
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03200
Shop #: WSC 02609
VCID: 3261EAE7FE6185D27A-513C
WAUVT68E34A039937 AUZ6Z0C0188654
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 63251
VCID: 71E325EB3BE7FECA43-4B00
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortger·t T7B 1411
Coding: 12044
Shop #: WSC 63251
VCID: 72E12AE73EE1C5D2BA-4B00
Subsystem 1 - Part No: 8E1959801
Component: Tırsteuer.FS BRM 0003
Subsystem 2 - Part No: 8E1959802E
Component: Tırsteuer.BF BRM 0003
Subsystem 3 - Part No: 8E0959801A
Component: Tırsteuer.HL BRM 0003
Subsystem 4 - Part No: 8E0959802A
Component: Tırsteuer.HR BRM 0003
8 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
00955 - Key 1
00956 - Key 2
35-00 - -
01561 - Rear left door
59-10 - Can't Unlock - Intermittent
01562 - Rear right door
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0260
Coding: 01005
Shop #: WSC 68096
VCID: 2C5DF49FDC45D32230-50AC
2 Faults Found:
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
00879 - Connection to Speaker Front Right
End-------------------------(Elapsed Time: 05:53)--------------------------
Cleared codes, ran TBA, test drove and less than a block away the CEL, EPC and limp mode initiated.
Ross-Tech suggests the accelerator pedal sensors rarely take a ****, however, the O2 sensors and their wiring may be a culprit. This car had JHM downpipes installed a couple years ago and I assume the installer reattached the O2 sensors correctly. I also sent the ECU and TCU to JHM a couple years ago for upgraded tunes.
My thoughts are to inspect the O2 sensors next and pull the ECU again and inspect the connectors at the bottom of the ECU housing for moisture. I'd take a closer look at the throttle body sensors and wiring, however, I am not finding any information related to throttle body sensors and related wiring for a 3.0. Any help or suggestions that members can provide is appreciated.
Thanks~Mark
www.Ross-Tech.com
67 69 75 76 77
Coding: 0016751
2 Faults Found:
Coding: 0001002
Coding: 04497
Shop #: WSC 01234
2 Faults Found:
Coding: 00000
Shop #: WSC 63251
Coding: 01013
Shop #: WSC 63251
1 Fault Found:
Coding: 0010607
Coding: 02042
Shop #: WSC 63251
Coding: 03200
Shop #: WSC 02609
Coding: 00002
Shop #: WSC 63251
Coding: 12044
Shop #: WSC 63251
8 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
35-00 - -
Coding: 01005
Shop #: WSC 68096
2 Faults Found:
Thanks~Mark
