Nice work Mathieu,
Did you get my email about manual calibration?
Intuitively this statement makes good sense, but the reality with our sensors and the e-Level system is that as long as you have over 1" of travel, you will not see a noticeable difference in accuracy or performance. This is because the sensor itself puts out an infinitely accurate output by using non-contacting magnetic technology. The e-Level controller will then calibrate to the lower sensor travel and span the total travel to 100%. So definitely staying on the safe side of sensor travel is better than over extending the thingsSensitivity will be low but you are right.
Better to be to short, rather than to long and snap a sensor. :thumbup:
thanks for the clarification Reno, I'm glad I didn't waste timeIntuitively this statement makes good sense, but the reality with our sensors and the e-Level system is that as long as you have over 1" of travel, you will not see a noticeable difference in accuracy or performance. This is because the sensor itself puts out an infinitely accurate output by using non-contacting magnetic technology. The e-Level controller will then calibrate to the lower sensor travel and span the total travel to 100%. So definitely staying on the safe side of sensor travel is better than over extending the things![]()
Wow.Intuitively this statement makes good sense, but the reality with our sensors and the e-Level system is that as long as you have over 1" of travel, you will not see a noticeable difference in accuracy or performance. This is because the sensor itself puts out an infinitely accurate output by using non-contacting magnetic technology. The e-Level controller will then calibrate to the lower sensor travel and span the total travel to 100%. So definitely staying on the safe side of sensor travel is better than over extending the things![]()
I used 9 sheets of 1.67 sq. feet each ($100 CAD total) locally picked up at Hotrod Corner in Surrey BC,how much of that did you pick up? and where?
I should apply some while the truck setup is getting redone.
