All:
I want to add a temp gauge to my beetle. I could cut a hose and install a sender. here's the deal, however. there is a perfectly good sensor installed in the car already, I just don't have an easy way to read the circuit.
According to my shop manual, the temp sensor has 4 pins, 2 of which are the temp resistor. The resistance goes from around 1kohms at room temp, to 250 ohms at operating temp (like a standard VDO sender)
Your homework assignment, should you chose to accept it, is to develop a circuit to monitor this resistance, without actually changin it. That way your temp gauge will work, and you don't screw up the engine computer.
Any ideas? Something along the idea of a shunt or brodge, I would guess. Any electrically inclined readers out there?
