1 - 6 of 6 Posts
Im almost done part collecting for my 16v g60. But i need to know bout head gaskets. WHat better copper or aba head gasket? Or something else? Ive heard ABA is better now if go with aba do i use one or stack them to lower compression? Same with copper- do i stack them or just 1? Thanks.
Re: Adding boost to my 16v- Which head gasket?????? (Boosted8v)
IMO the ABA is great, I have used 2 on 16v 9a motors which lowers the compression somewhere around 9:1, this worked great and has seen 16 psi, make sure if you use the aba headgaskets you use arp head bolts and torque them to at least 80 ft lbs.
Re: Adding boost to my 16v- Which head gasket?????? (TURBOPHIL)
So do you stack them or just use 1?
Discussion Starter · #4 ·
OK never mind. I did some research and im going to stack 2 ABA headgaskets to lower my compression to somewhere between 8-1 to 8.5-1. Thanks.
any mods needed to use the ABA gasket on the 9A bottom with a PL head?
Re: Adding boost to my 16v- Which head gasket?????? (qwikxr)
Yeah, you gotta file out one of the mounting holes slightly, not a big deal. BUT a company does make a copper gasket to lower the compression, it's like $100 though, and it's copper = copper sucks.
http://www.bildon.com/catalog/engine/
1 - 6 of 6 Posts
