So I know threads like this seem to come up all the time. Someone got a great deal on the controller from a junk yard and cant wait to get it installed. Well, I got my good deal on the parts and it should be in by the end of this week. To do the swap here are basicly all the parts you need:
First off, you need the control unit:
Then you have the big item which makes this install a total PITA which is the airbox. To install this you will need to get the AC system evacuated and remove the entire dash to get access to it.
Then the wires:
Wiring for this is pretty straight forward after you spent a good number of hours reading the bentley manual. wiring has to be done at the plenum, at the airbox, at the fusebox, at the fan control module and at the cluster and possibly windshield wiper relay. Along with wiring in the outside air temp sensor if you dont already have it.
I should have it in my car and done by the end of the week. I am only waiting now for the 2 seals for the evaporator connection and then to get the system evacuated.
Two years after SVTWEB sold his car and I have almost caught up with him.....
Then the wires:
