Which line do I hook it up to? Theres 2 and they both the same nozzle? Cant tell which is the high or lo side, need help im sweatin my balls off!!!!
Quote, originally posted by tadr_94jetta » |
i just did mine as well... the refrigerant was so low that the pressure switch didn't even trigger the compressor. Soo... I forced the compressor on (there is a harness hooked to the receiver dryer in front of the passenger side wheel under the car, short pins 1 and 2). Then I pumped 134A into the low side line on the passenger side near the firewall. All you need to do is get a couple of cans form the auto parts store and the valve/hose. Stay away from the aerosol quick cool cans, they leak something terrible. A big note of caution however. Doing it this way does NOT ensure that you get the exact correct pressure. Maybe buying a gauge would solve this. |
Quote, originally posted by MerryBerry » |
He's got a 97 Jetta, not an 88.
