Adding some subs in the back...
392 Views 6 Replies 3 Participants Last post by  -=VdubGuY=-
OK, I have a 2001 GTI with the 6 disk mosoon system. When I looked back there, there seems to be all the wires I need to hook up another amp ( I didnt look to closely) Should I run new wires or could I split off the wires going into to the amp. What is the easiest and best looking about of doing this? Any info would be appreciated. TIA
Cross posted in Car Ausio Also
DAVE
1 - 7 of 7 Posts
Re: Adding some subs in the back... (-=VdubGuY=-)
The only wire u need are the power wire. All amp should have its own power directly from the batt and fused of course.
Im assuming u want to use a level line converter to get the signal to the amp. If not and u plan to go with a new HU, u need to run signal RCA cables back.
Re: Adding some subs in the back... (1BadAzzVR6)
quote:[HR][/HR]The only wire u need are the power wire. All amp should have its own power directly from the batt and fused of course.
Im assuming u want to use a level line converter to get the signal to the amp. If not and u plan to go with a new HU, u need to run signal RCA cables back.[HR][/HR]​
So other than the constant power wire is it plug and play?
EDIT : will I need to get another wiring harness for the high level outputs? our should I just split them? And DETAIL information is appreciated, I am new to the A4's TIA
Dave
[Modified by -=VdubGuY=-, 9:10 PM 11-23-2001]
See less See more
TTT
Anyone? DETAILED instructions on how to this would help. So far I know I have to run a new constant power wire for the amp, that is obvious. But what about the speaker inputs and the turn on switch? Can I just splice them from the CD changer? Could it be possible to get a harness that "y"s? You know go from one harness and make it two, so that this way I dont have to splice into the CD changer. TIA
DAVE
u might also want to try the audio forum for more responses
Re: Adding some subs in the back... (VR6 Kid)
quote:[HR][/HR]u might also want to try the audio forum for more responses[HR][/HR]​
Yeah, I cross posted this there also, that forum seems pretty slow though, so I figured I would try them both.
Dave
1 - 7 of 7 Posts
