1 - 6 of 6 Posts
Vag is finally coming up clean for me after some TB problems that went away after some extensive engine searching. (checking all vacume lines/electrical+sensor connections, only not finding any problems but something must have been loose for the EPC to get thrown)
but i have this now>>
CAR: 01 Jetta 1.8t AWW. APR 93.
Codes:
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 D
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00066
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
(every other block showed no faults)
also, i looked through all my vag logs back to the first time i scanned my car using vag in April 2005, and found this set of codes, then again in July 2006. no CEL at the time, but this came up:
Coding: 0018945
Shop #: WSC 00066
2 Faults Found:
00668 - Supply Voltage Terminal 30
008 - Implausible Signal - Intermittent
the 00668 - Supply Voltage code has not come up since, that i know of.
i believe this code (00668) showed up before the VW dealer told me that my ABS light needed the ABS computer reflashed. at least that was what i was told. the invoice was not very specific. i had an ABS light, NO CEL, which would flash whenever i'd apply any amount of braking and then stay on. but the dealer hasn't mentioned it since and i have been there a few times since the July 2006 00668 code.
00668 does not show up now so i am not that worried about it. only the 01314 Check DTC memory code.
edit:
i have recently pulled the ECU, but this 01314 code showed up a year ago, and a year before that. it is very intermittent like the code says...
so i don't think pulling the ECU would cause it.
Modified by toywolf at 4:37 PM 5-13-2007
Discussion Starter · #4 ·
Re: Address 03 >> 01314 ([email protected])
note: does not throw a CEL, its just "there" in the codes...
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01 -------------------------------------------------------
Controller: 06A 906 032 DL
Component: 1.8L R4/5VT G02 0004
Coding: 07500
Shop #: WSC 00000
No fault code found.
Coding: 0018945
Shop #: WSC 00066
1 Fault Found:
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 905 J
Component: A4-KOMBIINSTR. VDO V52
Coding: 07232
Shop #: WSC 00066
IMMO-IDENTNR: VWZ7Z0Y2882165
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 00066
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
Address 56 -------------------------------------------------------
Controller: 1JM 035 157 A
Component: Radio DE2 0005
Coding: 02043
Shop #: WSC 01312
End -------------------------------------------------------
Vendor
Re: Address 03 >> 01314 (toywolf)
Normally you would only see that 01314 code if the engine has a fault code that affects the ABS. If the ECU is free of faults, you should be able to clear the 01314 code and it should stay away. If you can't clear it, or if it comes back without the ECU also having a fault, I would say there's something strange going on, but I have no real insight what it is.
If it was my car and the ABS worked, I wouldn't worry about it a whole lot.
-Uwe-
1 - 6 of 6 Posts
