1 - 2 of 2 Posts
A while ago I replaced the Monsoon headunit in my 2001.5 Passat with an Alpine 9857 but kept the factory Monsoon amp/x-over and speakers. Everything worked perfectly until the other day, when I replaced the car's battery as part of the car's routine maintenence. Now the Alpine HU powers up and appears to work normally (tuner, CD, iPod, Sat), but no sound comes out of the speakers. (No static, no popping -- absolutely nothing).
I suspect that disconnecting the battery leads to the car may have caused something w/ what's left of the Monsoon system to reset, or perhaps tripped some kind of anti-theft system, but I have no clue how to fix it.
Anyone encountered this problem?
Mark
Re: After car battery change, Alpine 9857 in Passat w/ Monsoon Amp = No Sound (markw123)
You need to turn the powerIC off. When the radio looses vmem, it turns the power IC off - mine does at least and it's a 9860.
hold the menu button until the menu comes up
press >> until you get to power IC
press mode
turn volume knob to change setting
press menu to finish
rock out
1 - 2 of 2 Posts
