Re: After market CD Changer for Eurovan (Vunderboos)
Easiest thing to do? Just pull the radio out and see if the cable is plugged into the back of the radio. If you can find the tool to remove the head unit, I made one from a hacksaw blade. I took a grinder to the toothy side of the blade and ground it to the right width. Works fine.
If the wiring is there, there will be a smaller (9 pin?) plug along with the 2 main larger plugs.
