1 - 6 of 6 Posts
Discussion Starter #1
Greetings,
recently I changed RCD 510 to aftermatker head unit AMC 886 Pro (Android). lt's working well - I have control from steering wheel, some information are avaiable on HU screen. Only problem is there is no sound from rear speakers. On interenet there is a lot of simmilar problems, but I can't find 100% like mine. Originally, RCD 510 was connected to stock amp 5K0 035 456. What could be a reason of that? Do I need check amp coding with VCDS?
my car: 2009 Passat B6 2.0 TDI CBAB
ps. I apologize, if there is topic like mine.
Go into the factory settings menu (code 126) and see if there's any way to enable additional speakers there. I had to do that.
Sent from my Pixel 3 using Tapatalk
I’m having the same issue on an Eonon GA9453B that I just installed. All speakers work except for the rear ones. I have the Fender system in my Passat.
We’re you able to fix it by enabling more speakers in settings?
Did you ever figure this out?
1 - 6 of 6 Posts
