1 - 5 of 5 Posts
Discussion Starter #1
I am getting a code for my seat belt buckle tension is off or something. Does anyone know what could be causing this? It is setting my airbag light off. Thanks, D
Senior Member
Re: Air Bag Fault Help (gadstrike08)
one of your seatbelt tensioners is bad. you need a vagcom to find out which one, then replace, there is no repair.
Senior Member
Re: (gadstrike08)
Quote, originally posted by gadstrike08 »
is the tensioner the entire thing you buckle it into?
yes...this is a common issue on older MKIV's...most dealers stock these, but you can get them on-line much cheaper.
1 - 5 of 5 Posts
