1 - 3 of 3 Posts
Today both the CEL and airbag light went on. I reset the CEL and pulled a 0411 code however there wasn't a code for the airbag. The 411 is a bad hose to the DV that i will fix when it gets a little warmer.
Any suggestions on the airbag light. My car is a 2000 1.8T NB with 26000 miles and about 30 months old. Should this problem be covered by the warranty?
Thanks Tom
Re: Air bag light (vwautotech)
Dave,
I not able to pull any codes with OBD2 tester other than the o411. I've cleared that code and have fixed the vacuam hose to the DV. The CEL is off however the airbag light comes on when you turn the key to on position goes off for about one second when you start then it comes back on and stays on.
I call the VW customer line they said they may authorize a repair however i would need to have diagnostic performed before they could decide the outcome. Sounds like a fee to me. Is this common probelm???
Thanks Tom
1 - 3 of 3 Posts
