Imagine a suspension system that allows a super-low stance, track-tuned handling and raised ground clearance–at the push of a button–for everyday driving. It sounds too good to be true, doesn't it? Welcome to the reality that is Air Lift Performance...
This high-performance, Slam Series kit was specifically designed for the Volkswagen MK5/6 Golf platform, which gives you the ability to adjust the ride height even while on the move. At the touch of a button, you can lower your VW up to 5.8 inches on the front and rear axles. The result is a car that not only looks incredible, but also boasts a significantly improved suspension performance with the ability to maintain total practicality on the street.
AK7Z4727
Put simply, coilover suspensions cannot compete with the versatility of Air Lift Performance's setups. This kit will get your vehicle lower than any coil suspension, while still providing crisp handling and a smooth ride. Both the front and rear kits use double-bellow air springs. In order to achieve the lowest drop possible, the Air Lift Performance bags compress to an amazingly slim 2.3 inches, allowing even the biggest wheels to tuck hard (as long as they clear the fenders).
Air Lift Performance torture-tests each component on our hydraulic rig for over one million cycles, simulating around 100,000 real-world miles. Anyone with the skills to wire a stereo and swap suspension components can have their car on the ground in only a matter of hours. Basic hand tools are the only things necessary to complete the job.
AK7Z4729
The Volkswagen MK5/6 2WD Slam Series kit is available with a range of Air Lift Performance management options, including their innovative 3H™ height + pressure sensing system. Air Lift Performance used a state-of-the-art 32-bit processor, advanced height + pressure algorithms and a full color controller, complete with built in Bluetooth connectivity to make 3H the most advanced air management system on the market.
